"nuovo" fuoristrada Renault
mac
mac ha scritto:
GN71 ha scritto:
Dabx ha scritto: chiamasi, come già detto da altri, brutta copia hummer!!!!!!!!!!!!!!!!!!!!! ho detto tutto!!!!!!!!!
Credo sia presto per giudicare, bisognerebbe saperne di più e vederlo nei dettagli.
E' un mezzo a balestre, sempre che la vista non mi inganni:
La coppia di 800Nm è poderosa, ma torno a dire che la potenza mi pare poca per la stazza. Non conosciamo il peso e le caratteristiche tecniche, e in ogni caso ci basiamo soltanto su foto.
A vederlo così non sembra malvagio, però.....boooh!
E' a molle
" The Sherpa 3 Special Forces is designed for intervention and special forces units."It can achieve a maximum speed of 120km/h on flat road surface. The cruising range of the vehicle is 850km at 70km/h with a 200l fuel tank capacity.
The engine is coupled to an automatic transmission Allison S2500 with six forward gears and one reverse gear.
The vehicle's front-drive axle has a load capacity of 3.5t and the rear drive axle has a load capacity of 6.5t.
The vehicle's drive-line solutions provide outstanding moving capabilities and tactical speed on the most difficult terrains under rigorous environments.
Mobility
The suspension provides a high ground clearance for the vehicle. The front suspension is equipped with pushing arms with coil springs and the rear suspension is fitted with trailing arms with coil springs . The other suspension components include telescopic shock absorbers and a stabiliser bar. The vehicle's overall turning radius is 7.5m.
Sherpa 3 has high cruising speed and is ideal for long-range movements on land. The compact silhouette allows the users to deploy the vehicle on any theatre and urban areas. The vehicle can be transported in C130, Chinook, B747 and A400 aircraft."
Non che lo sapessi, ho fatto una "ricerchina" :)
Dimenticavo: ha "ruotine" 335/80R20 oppure 13 R22,5
roberto94100
VIDEO REPORTER ORW
VIDEO REPORTER ORW
comunque a giudicare dalle foto...non è male
Non sarà male ma sempre un rimpasto dell'HUMMER SEMBRA!
Teo93
ummm non mi piace per niente, preferisco l'hummer
GNOTARO85
Mh non lo so bisognerebbe vederla in azione, puo darsi che poi i nostri 4x4 facciamo piu miracoli di questo "mezzo"
Ex Pajero 2500 td gls Offtech
EX Suzuki sj413 by Zanfi
Ex Toyota KZJ70 3.0TD
Trevis23
doppio ponte rigido vs indipendenti dell'hummer... :-o :-o :-o
NO MUD NO PARTY
mac ha scritto:
E' a molle
Ahhh! E dillo che sei un ricercatore :D
Ti raccomanderò per far coppia con la Fornerina :ride:))ride
Scherzi a parte, guardando le foto mi pareva di intravedere delle balestre... :non ...anche se mi sembrava strano.
Ma a te non sembra che la potenza sia bassa?
mac
GnoTaro85 ha scritto:Mhhhh :o
Niente di piu facile che visto il fallimento del marchio hummer abbiano rilevato la catena di montaggio
No! la catena di montaggio degli Hummer H1 è stata rilevata dai cinesi :sad:
poi per quanto riguarda la "cavalleria, certo non è "erntusiasmante", però c'è da dire che i suoi "simili" militari hanno potenze analoghe:
190 cv il Lince
205cv hummer h1
In effetti, visto che lo hanno "civilizzato", qualche cavallino in più non sarebbe stato controproducente :)
stefanob ha scritto:Sembra un'autoblindo per trasporto valori.
Stavo per dire la stessa cosa, mi ricordano i vecchi film francesi, non sò esteticamente è la fotocopia dell'Hammer e tanta sete di carburante, meglio dell'Hammer sono idoppi ponti rigidi, roba da legionari.
Per l'esercito và bene ! :)
Per Off Road nelle nostre piste assolutamente inadatto troppo mastodontico ma soprattutto troppo largo!
Forse per gli Arabi và bene per noi no !!!
P.S. già nei tracciati sopra Taormina fino a Messina è difficilissimo transitare con un GR figuriamoci con questo ! :sad:
the Saw
Carino....ma adatto solo x uso militare...quoto Jacoterrano... :smile:
Onofrio
Ciao a tutti,
l'Hummer H1 è un mostro di potenza.
https://en.wikipedia.org/wiki/Hummer_H1
Ecco a voi un po di scheda tecnica ma come dite voi ci vogliono dei bei soldi per averlo.
Saluti a tutti.
__________________
Auto elettriche, Colonnine e forum twizy > ForumElettrico.it
Torna a “Area 4x4”
