Fildena 100 is a popular oral medication used to treat erectile dysfunction. For many men, it provides a safe and effective way to achieve and maintain an erection. However, to get the best results from Fildena 100, it's important to understand how it works and how to take it properly. In this guide, we'll cover tips and best practices for maximizing your performance when using this medication.
The first thing to know is that Fildena 100 contains sildenafil citrate, which is the active ingredient that helps achieve an erection. It works by increasing blood flow to the penis during sexual stimulation. However, it does not cause an erection without sexual stimulation. For this reason, it's important not to take Fildena 100 without the intention of being sexually active. Plan ahead and only take it when you expect intimacy within the next 4 hours.
When taking Fildena 100, aim to do so approximately 1 hour before sexual activity. Give the medication time to be absorbed into your system and take effect. You should not exceed one 100mg tablet in a 24-hour period. Taking more will not make the effects stronger or last longer - it will only increase side effects. Some common side effects include headache, flushing, indigestion, and congestion. These are usually mild.
